Shows or hides the Compare Means column in the Crosstab table. This column compares the mean scores across grouping categories using the unpooled Satterthwaite t test for pairwise comparisons. See SAS Institute Inc. (2017). The results of the comparison are shown using letters. For more information about comparison letters, see Comparison Letters. For more information about specifying comparison groups, see Example of User-Specified Comparison with Comparison Letters.
Save t tests and p-values from the Mean Score Comparisons report to a new data table.
Shows or hides the local data filter that enables you to filter the data used in a specific report. Sample levels that contain no responses are always hidden. To show the filtered headings in reports, select Include Responses Not in Data in the launch window. You can also select the Set Preferences red triangle menu and then select Include Responses Not in Data.
See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information about the following options:
Help created on 10/11/2018
