Shows or hides (x, y) points. The points are hidden by default.
Shows or hides points with missing y values. Available only if Show Data Points is selected.
Shows or hides the Alpha slider that allows you to change the Alpha shapes filter.
If the contour plot includes a Color role, the Transform option is enabled. See Additional Example of Contour Plots for details.
Shows or hides the label (z-value) of the contour lines.
See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information about the following options:
Help created on 10/11/2018
