When you click Make Design, in most platforms, a Design Evaluation outline appears. Here you can explore the design that you created in terms of the following: its power to detect effects, its prediction variance, its estimation efficiency, its aliasing relationships, the correlations between effects, and other design efficiency measures. The Design Evaluation outline for a Custom Design is shown in Figure 2.22. Design Evaluation is covered in the Evaluate Designs topic.
Figure 2.22 Design Evaluation Outline in Custom Design
