Figure 19.18 Factors Outline
Enters the number of factors specified in Add N Factors. All factors are categorical. Select or specify the number of levels.
Adds multiple factors with a specific number of levels. Enter the number of factors to add, click Add Factor, and select or specify the number of levels. Repeat Add N Factors to add multiple factors with different numbers of levels.
Tip: When you have completed your Factors panel, select Save Factors from the red triangle menu. This saves the factor names and values in a data table that you can later reload. See Covering Array Options.
Factors Table
The name of the factor. When a factor is added, it is given a default name of X1, X2, and so on. To change this name, double-click it and enter the desired name.
Editing the Factors Table
To remove a factor level, click the value, click Delete, and click outside the text box.
Factor Column Properties
Help created on 10/11/2018
