Use Disallowed Combinations Filter
To remove a single factor, select Delete from its red triangle menu.
Blocks Display shows each level as a block.
List Display shows each level as a member of a list.
Single Category Display shows each level.
Check Box Display adds a check box next to each value.
Clear Find clears the results of the Find operation and returns the panel to its original state.
Match Case uses the case of the search string to return the correct results.
Contains searches for values that include the search string.
Does not contain searches for values that do not include the search string.
Starts with searches for values that start with the search string.
Ends with searches for values that end with the search string.
Figure 19.19 Script Window Showing Names of Levels in Quotes
Help created on 10/11/2018
