Adds simulated responses to the table when you click Make Table. The simulated responses are created by taking random draws from the chosen distribution at the parameter values specified in the Prior Mean outline. If a simulated response exceeds the specified test length, the observation is censored at the test length value.
Help created on 10/11/2018
