Denote the linear mixed model by E[Y|γ] = Xβ + Zγ. Here
is the vector of fixed effect coefficients and γ is the vector of random effect coefficients. The marginal predictions are the predictions from the fixed effects part of the predictive model, given by
Options that are appropriate for the model that you are fitting are enabled. See Figure 7.21 for an example of a profiler. See Figure 7.42 for an example of a Surface Profiler. For more details, see Surface Plot in the Profilers book.
Profilers
