Use the Axis property to change the default axis settings for a column. JMP automatically uses your settings when the column appears in an analysis. See Customize Axes and Axis Labels in the Axis Settings Window in JMP Reports for details about the properties.
When you add the Axis column property, you can save all column properties or only the properties that you changed. For example, you might want the axis to start at 0 and are not concerned about the upper bounds of the axis. Set the minimum axis value and select Changed Properties Only from the Save to column list.
Right-click the axis and select Save to Column Property.
