Tip: In addition to the main Data Filter, you can also launch a local Data Filter within a platform report. Click the Local Data Filter icon
from the Report toolbar, or select Local Data Filter from the red triangle menu in a report.
Figure 8.7 Initial Data Filter Window
To restore your current row states when the Data Filter window is closed, select the Save and restore current row states option.
Detach it temporarily by deselecting the Use Floating Window option from the Data Filter red triangle menu.
Detach it persistently by selecting File > Preferences > Tables and deselecting the Use a Floating Window for Data Filters option.
