JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Using JMP •
JMP Reports
The Data Filter
• Types of Filter Columns
There are three types of filter columns, as follows:
Continuous columns
Numeric columns whose modeling type is set to continuous. A continuous filter column is represented by a slider that spans the data range.
Categorical columns
Nominal and ordinal columns. For each categorical column, the Data Filter generates a set of distinct categories. These categories can be displayed in different forms.
Note:
For categorical columns with value labels, if you want to include responses that are not present in the data, select the
Include Responses Not in Data
option from
File > Preferences > Tables
Multiple Response columns
Character columns that have the Multiple Response column property or Multiple Response modeling type assigned. Each data cell of the column generally consists of multiple categories, separated by some common separator, like a comma. Since each data cell can contain more than one category, multiple response columns have a richer set of filtering options.
Help created on 10/11/2018
