Figure 2.5 The Initial Distribution Report Window
Note: To remove a variable, select Remove from the red triangle menu.
The red triangle menu next to each variable contains options that affect only that variable. See Options for Categorical Variables or Options for Continuous Variables. If you hold down the Control key and select a variable option, the option applies to all of the variables in the report that have the same modeling type.
Help created on 10/11/2018
