When you select the Tolerance Interval option for a variable, the Tolerance Intervals window appears. Use the window to specify the confidence level, the proportion to cover, a one-sided or two-sided limit, and the method. The two available methods are Assume Normal Distribution and Nonparametric. The Assume Normal Distribution option computes tolerance intervals that are based on the assumption that the sample was randomly selected from a normal distribution. The Nonparametric option computes distribution-free tolerance intervals.
Related Information
Help created on 10/11/2018
