To add an outline, right-click in the journal, and then select Append Item > Add Outline Item. You can also add nested outline levels to outline levels that you have created. (When you click the red triangle menu of a graph that you have journaled, the Add Outline Item option is unavailable.) Click the outline’s red triangle menu and select Add Outline Item.
To add text or links within an outline, click the outline’s red triangle menu and select an option described in Journal Right-Click Options. Note that these options are not available when you click a scripted item’s red triangle menu.
To edit the name of the link displayed in the journal, right-click the link, select Set Button Name, enter the new name, and then click OK.
