JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Profilers
• Excel Profiler
Excel Profiler
Visualize Models Saved in Microsoft Excel
The JMP Add-In for Excel uses the JMP Profiler to visualize models (or formulas) stored in Excel worksheets. The Excel add-in is automatically installed when you install JMP.
Profiler Using Excel Models Example
Contents
Excel Profiler Overview
Running the JMP Profiler
Example of an Excel Model
Using Linear Constraints
Resolution of Profile Lines
Using the Excel Profiler from JMP
