From the red triangle menu next to Prediction Profiler, select Alter Linear Constraints.
Click Add Constraint.
Click OK.
From the red triangle menu next to Prediction Profiler, select Save Linear Constraints.
6.
Click Yes.
Note: When you save the .xls file in Excel 2007, you might see a compatibility error. If so, click Continue to save the file.
