• JMP 12 Online Documentation (English)
    • Discovering JMP
    • Using JMP
    • Basic Analysis
    • Essential Graphing
    • Profilers
    • Design of Experiments Guide
    • Fitting Linear Models
    • Specialized Models
    • Multivariate Methods
    • Quality and Process Methods
    • Reliability and Survival Methods
    • Consumer Research
    • Scripting Guide
    • JSL Syntax Reference
    • JMP iPad Help
    • JMP Interactive HTML
  • Capabilities Index
  • JMP 13.2 Online Documentation
JMP Support 919.677.8008 (US)
Documentation Feedback
Your feedback is important to us. us any comments about our documentation.
Discovering JMP • Saving and Sharing Your Work
Saving and Re-creating Results
Once you have generated results from your data, JMP provides you with multiple ways to share your work with others. Here are some of the ways that you can share your work:
Saving platform results as journals or projects
Saving results, data tables, and other files in projects
Saving scripts to reproduce results in data tables
Creating Adobe Flash (SWF) versions of platform results
Saving results as Interactive HTML (.htm, html)
Saving results as a PowerPoint presentation (.pptx)
Example of an Adobe Flash (SWF) Bubble Plot
Contents
Saving Platform Results in Journals
Example: Creating a Journal
Adding Additional Analyses
Creating Projects
Using Scripts
Example: Saving and Running a Script
About Scripts and JSL
Saving as Interactive HTML
Interactive HTML Contains Data
Saving as a PowerPoint Presentation
Creating Adobe Flash Versions of the Profiler, Bubble Plot, or Distribution Platforms
