Using JMP > Save and Share Your Data > Create Journals > Add a Graph or Graphic to Journals
Publication date: 03/03/2025
PNG, GIF, JPG, BMP, and TIF files are supported in journals. Do one of the following to add a graphic to a journal:
• Copy a graph from within JMP or a graphic from another application and then select Edit > Paste. JMP places the graphic at the end of the journal.
• Drag and drop the graph or graphic from another window to the journal. (See Paste a Background Image into a JMP Graph.) A blue line indicates where you can drop the graphic.
Tip: Consider resizing the graphic in an external program. Then you can insert the graphic at 100% resolution in the journal without dragging to resize the graphic.
