Publication date: 03/03/2025
Create New Journals
1. Close all open journals, and do one of the following:
– To create an empty journal, select File > New > Journal. Or, from the JMP Starter window, select New in the Journal section.
– To create a journal from an entire report or data table, select Edit > Journal.
– To create a journal from a specific report or text in a report, click and drag the selection (Image shown here) tool to select adjacent items in a report or data table. To select discontinuous items, press Shift and click the items with the selection (Image shown here) tool. Then select Edit > Journal.
– To create a journal from specific text in a data table, select the text, and then select Edit > Journal.
– To create a journal from most graphs, right-click the graphic, and then select Edit > Journal. (Not available for surface plots and 3-D scatterplots.)
Tip: If you prefer keyboard shortcuts, press Ctrl+Shift+J (Windows) or Command+J (macOS) to create the new journal.
2. Select File > Save and save the journal in .jrn format.
