Using JMP > Reshape Your Data
Publication date: 03/03/2025
Reshape Your Data
Create Subsets, Sort Data, and More
This chapter covers the following tasks that you can perform on JMP data:
• create a new data table from a subset of rows and columns
• sort by any number of columns
• stack multiple columns into a single column
• split a column into two or more columns
• transpose rows and columns
• concatenate multiple tables end to end
• join two tables side by side
• virtually join tables without physically joining them
• update columns in a table with values from another table
• anonymize the data
Figure 6.1 Creating a Subset Data Table from a Report
Contents
Create a Subset Data Table
Create a Subset Data Table from a JMP Report
Sort Data Tables
Stack Columns in Data Tables
Example of Stacking Columns into a Single Column
Example of Stacking Columns into More Than One Column
Split Columns in Data Tables
Examples of Splitting Columns
Transpose Rows and Columns in a Data Table
Examples of Transposing Rows and Columns in a Data Table
Concatenate Data Tables
Example of Concatenating Data Tables
Example of Concatenating Data Tables and Table Variables
Join Data Tables
Examples of Joining Data Tables
Query and Join Data Tables with JMP Query Builder
About Links to Data Tables in JMP Queries
Virtually Join Data Tables
Example of Virtually Joining Columns
Example of Virtually Joining Columns and Showing Row States
Example of Merging Referenced Data in Virtually Joined Data Tables
Example of a Link ID and a Link Reference on a Single Column
Update Data Tables
Example of Updating a JMP Data Table
Anonymize Data
