Publication date: 03/03/2025
Statistical Details for Fit Curve Models
The formulas for the models that are available in the Fit Curve red triangle menu are summarized in Table 14.1.
Table 14.1 Fit Curve Model Formulas
Model
Formula
Polynomials
Equation shown here
where k is the order of the polynomial. These models can also be fit using the Fit Model and Fit Y by X platforms.
Power Model
Equation shown here
a = Intercept
b = Slope
c = Power
Available only when both the response values and the x values are nonnegative.
Logistic 2P
Equation shown here
a = Growth Rate
b = Inflection Point
Available only when all response values are between zero and one.
Logistic 3P
Equation shown here
a = Growth Rate
c = Asymptote
Logistic 4P
Equation shown here
a = Growth Rate
c = Lower Asymptote
d = Upper Asymptote
Logistic 4P Rodbard
Equation shown here
a = Growth Rate
b = Location
c = Lower Asymptote
d = Upper Asymptote
Available only when the x values are positive.
Logistic 4P Hill
Equation shown here
a = Growth Rate
c = Lower Asymptote
d = Upper Asymptote
Logistic 5P
Equation shown here
a = Growth Rate
b = Location
c = Asymptote 1
d = Asymptote 2
f = Power
Probit 2P
Equation shown here
a = Growth Rate
Φ = Normal Distribution CDF
Probit 3P
Equation shown here
a = Growth Rate
c = Asymptote
There is also an asymptote at zero.
Probit 4P
Equation shown here
a = Growth Rate
c = Lower Asymptote
d = Upper Asymptote
Gompertz 3P
Equation shown here
a = Asymptote
b = Growth Rate
c = Inflection Point
Gompertz 4P
Equation shown here
a = Lower Asymptote
b = Upper Asymptote
c = Growth Rate
d = Inflection Point
Weibull Growth
Equation shown here
a = Upper Asymptote
b = Location
c = Growth Rate
Exponential 2P
Equation shown here
a = Scale
b = Growth Rate
Exponential 3P
Equation shown here
a = Asymptote
b = Scale
c = Growth Rate
Biexponential 4P
Equation shown here
a = Scale 1
b = Decay Rate 1
c = Scale 2
d = Decay Rate 2
Available only when the response values are positive.
Biexponential 5P
Equation shown here
a = Asymptote
b = Scale 1
c = Decay Rate 1
d = Scale 2
f = Decay Rate 2
Mechanistic Growth
Equation shown here
a = Asymptote
b = Scale
c = Growth Rate
Hybrid Exponential
Equation shown here
a = Maximum
b = Scale
c = Rate
d = Power
Cell Growth 4P
Equation shown here
a = Peak value if mortality rate, d, is zero
b = Response at time zero
c = Cell Division Rate
d = Cell Mortality Rate
Available only when the response values are positive and the x values are nonnegative.
Gaussian Peak
Equation shown here
a = Peak Value
b = Critical Point
c = Growth Rate
Asymmetric Gaussian Peak
Equation shown here
a = Critical Value
b = Scale 1
c = Scale 2
d = Peak Value
Available only when the response values are nonnegative.
Skew Normal Peak
Equation shown here
a = Location
b = Scale
c = Skew
d = Peak Value
φ = the standard normal pdf
ExGaussian Peak (Exponentially Modified Gaussian Peak)
Equation shown here
a = AUC (area under the curve)
b = Location
c = Scale
d = Lambda
Pseudo-Voigt Peak
Equation shown here
d = Mixing Parameter
l(x) = evaluation of Lorentzian Peak function
g(x) = evaluation of Gaussian Peak function
Pearson VII Peak
Equation shown here
a = Location
b = Scale
c = Shape
d = Peak Value
Lorentzian Peak
Equation shown here
a = Peak Value
b = Growth Rate
c = Critical Point
One Compartment Oral Dose
Equation shown here
a = Area Under Curve
b = Elimination Rate
c = Absorption Rate
Available only when the response values and the x values are all positive.
Two Compartment IV Bolus Dose
Equation shown here
α =Equation shown here
β =Equation shown here
a = Initial Concentration
b = Transfer Rate In
c = Transfer Rate Out
d = Elimination Rate
Michaelis-Menten
Equation shown here
a = Maximum Velocity
b = Michaelis Constant
Inverse Michaelis-Menten
Equation shown here
First Order Rate
Equation shown here
a = Initial Value
b = Rate Constant
Available only if the x values are nonnegative.
First Order with Limits
Equation shown here
a = Initial Value
b = Limiting Value
c = Rate Constant
First Order with Equilibrium
Equation shown here
a = Initial Value
b = Forward Rate
c = Backward Rate
Second Order
Equation shown here
a = Initial Value
b = Rate Constant
Second Order with Two Components
Equation shown here
a = Initial value
b = Offset
c = Rate Constant
Available only if all x values are nonnegative.
Antoine Equation
Equation shown here
a = Component Specific Constant
b = Component Specific Constant
c = Component Specific Constant
Available only when the response values are greater than 0.
The vertical asymptote is at 10a.
The horizontal asymptote is at −c.
Higuchi
Equation shown here
a = Release Constant
Available only if all x and y values are nonnegative.
Higuchi with Lag
Equation shown here
b = Time Lag
Higuchi with Burst
Equation shown here
b = Burst
Hixson-Crowell
Equation shown here
Hixson-Crowell with Lag
Equation shown here
Korsmeyer-Peppas
Equation shown here
b = Diffusional Exponent
Korsmeyer-Peppas with Lag
Equation shown here
c = Time Lag
Korsmeyer-Peppas with Burst
Equation shown here
c = Burst
