Predictive and Specialized Modeling > Bayesian Optimization > Bayesian Optimization Platform Options > Bayesian Optimization Batch Customizer Report Options
Publication date: 07/15/2025
Image shown hereBayesian Optimization Batch Customizer Report Options
The Bayesian Optimization Batch Customizer red triangle menu in the Batch Selection tab of the Bayesian Optimization platform contains the following options:
Augmented Prediction Profiler
Shows or hides the Profiler section of the report.
Load Candidate Set from Data Table
Loads a candidate set from an existing data table. When you select this option, the existing candidate set is removed and replaced by the factor combinations in the selected data table. The report title then includes the name of the data table.
Generate Candidate Set from Profiler Settings
Generates a candidate set of the specified number of rows by using the settings from the prediction profiler. When you select this option, the existing candidate set is removed and replaced by factor combinations that are generated from the profiler settings. The profiler factor ranges are used to generate the desired space filling sample.
