Predictive and Specialized Modeling > Gaussian Process > Gaussian Process Platform Options
Publication date: 07/15/2025
The Gaussian Process red triangle menu contains the following options:
Profiler
Opens the standard Profiler. See “Profiler” in Profilers.
Contour Profiler
Opens the Contour Profiler. See “Contour Profiler” in Profilers.
Surface Profiler
Opens the Surface Profiler. See “Surface Plot” in Profilers.
Save Prediction Formula
Creates a new prediction formula column in the active data table.
Save Variance Formula
Creates a new variance formula column in the active data table.
Image shown herePublish Prediction Formula
Creates a prediction formula and saves it as a formula column script in the Formula Depot platform. If a Formula Depot report is not open, this option creates a Formula Depot report. See “Formula Depot”.
Image shown herePublish Variance Formula
Creates a variance formula and saves it as a formula column script in the Formula Depot platform. If a Formula Depot report is not open, this option creates a Formula Depot report. See “Formula Depot”.
Save Jackknife Predicted Values
Saves the jackknife predicted values to the active data table. These are the X-axis values for the Actual by Predicted Plot.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
