Essential Graphing > Graph Builder > Pop-Up Menus in Graph Builder
Publication date: 07/15/2025
Numerous options are contained in Graph Builder pop-up menus. The specific menu options depend on where in a graph that you click, and the types and number of variables in your graph. Descriptions for the pop-up menu options are grouped in the following categories:
• Graph Options
• Grouping Zones Options
• Options for Columns in the Variables Panel
• Options for Axes, Axes Variable Labels, or Graph Titles
• Options for the Dividing Line between Multiple Graphs
• Legend Options in Graph Builder
For multiple graphs (created with grouping zones or the Wrap zone), note the following information:
• Generally, any options that you apply to one graph element apply to all graphs, across all grouping and wrap variables.
• To apply an option to only one graph, right-click in that graph area and select the option from the Graph menu.
• To apply an option to all of your multiple graphs simultaneously, press Ctrl, right-click, and then select the option from the Graph menu.
