Publication date: 07/15/2025
Image shown hereStabilized Weights
Stabilized weighting is another technique for reducing the variance of the causal effect estimate. When this box is not checked, weights are calculated using the following equations:
w = 1/p(X|Z)
where
X is the binary treatment variable
Z is the set of pre-treatment covariates specified in the treatment model
p(X|Z) is the probability of receiving treatment given covariates Z, calculated using the fitted treatment model.
Alternatively, stabilized weights are calculated using the following equation:
wstabilized = p(X)/p(X|Z)
where p(X) is the marginal probability of receiving treatment, calculated using a fitted intercept-only model.
