Using JMP > Create Formulas in JMP > Order Expressions in Formulas > Build a Formula in Order of Precedence
Publication date: 01/13/2026
It is best to build a formula that starts with any expression that serves as an argument. This is because functions have a high order of precedence and are always grouped with their corresponding arguments. It is also a good idea to create expressions by working from the highest to the lowest order of precedence when possible. If you need parentheses, be sure to enter the open parenthesis before entering the expression to be enclosed.
For example, given a data table with the columns A, B, and C, use the following steps to compose the expression A(B + C). Note that this expression is not the same as A x B + C, which evaluates as (A x B) + C.
To enter the expression, follow these steps:
1. Click column A in the Columns list.Image shown here
2. Click the multiplication button Image shown here in the Formula Editor keypad.Image shown here
3. Enter an open parenthesis.Image shown here
4. Click column B in the Columns list.Image shown here
5. Click the addition button Image shown here in the Formula Editor keypad.Image shown here
6. Click column C in the Columns list.Image shown here
Because the order of precedence determines which arguments are affected by each function, it also affects the grouping of expressions. Select functions in the formula to verify how the order-of-precedence rules have been applied.
Structure Formulas for Efficient Evaluation
Usually, it is not necessary to structure formulas with efficient evaluation as a priority. Most formulas evaluate almost instantaneously regardless of their structure. This is because statistical functions and constant expressions are evaluated only once when a column’s values are calculated.
However, when you are creating conditional expressions, remember that the Match conditional evaluates faster and uses less memory than an equivalent Condition function, If. (Note that Match ignores trailing spaces and If does not.)
For example, in the Big Class.jmp file, you can predict a child’s height from the child’s age, as shown in Figure 7.14. There is a base height of 58.125 inches to which a quantity is added depending on the value of the age variable.
Figure 7.14 The Match Conditional Evaluates Faster Than the If Function
The Match conditional evaluates faster than the If function because the age variable is evaluated only once for each row in the data table. The If condition must evaluate the age variable at each If clause for each row until a clause evaluates as true.
