Using JMP > JMP Reports > Change the Appearance of JMP Graphs
Publication date: 01/13/2026
There are many ways that you can format your JMP report to meet your needs. The following sections explain how to make changes to the graphical portions of your output reports.
Tip: If you have a touchscreen, you can pan and zoom most graphs and axes in JMP. Graphs and axes change scale and zoom out if pinched, and zoom in if stretched.
• Resize Graphs
• Zoom In on Graphs
• Change Line Widths in Graphs
• Change the Background Color in Graphs
• Change the Color of Histogram Bars
• Display Coordinates and Temporary Reference Lines in Graphs
• Scroll and Scale Axes in Graphs
• Customize Axes and Axis Labels in Graphs
• Change the Order of Values in Reports
• Change the Pattern and Format of Selected Objects in Graphs
• Add a Graph to a Data Table
• Customize Markers, Lines, Text, and More in Graphs
