Using JMP > JMP Reports > Change the Appearance of JMP Graphs > Change the Pattern and Format of Selected Objects in Graphs
Publication date: 01/13/2026
In JMP graphs, patterns appear on some objects such as bars and maps when you select them. You can change the pattern for a specific object in the legend.
Right-click the item in the legend and select Fill Pattern to select a new pattern.
To remove the pattern, right-click the item again and select Revert.
Change the Format of Selected Objects in All Graphs
Select File > Preferences > Graphs (Windows) or JMP > Preferences > Graphs (Apple macOS) to change the Filled Areas preferences.
• To change the highlight on selected objects, select one of the following Filled Selection Mode preferences:
Selected Patterned
A striped pattern (the default setting)
Selected Darker
A solid darker color
Selected Outlined
An outline
Selected Same Color
The Fill Selection Color in the preferences formats the selected object.
Unselected Faded
A lighter color than the selected objects
• To change the color of selected rows in graphic objects when the Fill Selection Mode is “Selected Same Color”, click the Fill Selection Color bar. The default color is red.
