Using JMP > Set JMP Column Properties > About the Columns Manager > Columns Manager Red Triangle Menu Options
Publication date: 01/13/2026
The Columns Manager red triangle contains the following options:
Show Statistics
Displays summary statistics for each column, including Min, Max, N Missing, N Unique, a Distribution graph, and All Integers. Character columns have Distribution and All Integers only. This option is selected by default.
Show Attributes
Displays column attributes. This option is selected by default.
Show Properties
Displays column properties. This option is selected by default.
Hide Excluded Columns
Hides columns that have the excluded flag. This option is selected by default.
Columns excluded since the Columns Manager has been opened still appear in the column list. Deselect and reselect the Hide Excluded Columns option or close and reopen the Columns Manager to hide them.
Hide Hidden Columns
Hides columns that have the hidden flag. This option is selected by default.
Columns hidden since the Columns Manager has been opened still appear in the column list. Deselect and reselect the Hide Excluded Columns option or close and reopen the Columns Manager to hide them.
Force calculations for all numeric columns
Specifies whether to calculate numeric statistics for all numeric columns. This option is deselected by default.
When selected, Columns Manager calculates the following statistics by default:
– For Continuous columns: N Unique
– For Nominal columns: Min and Max
Force calculations for all categorical columns
Specifies whether to calculate statistics for all categorical columns. This option is deselected by default.
– For Unstructured Text columns: N Missing and N Unique
– For None type columns: N Unique
Create Data Dictionary
Creates a detailed summary of the attributes, description, data info, and properties for each column in the data table as a JMP Journal. See “Create Journals”.
Choose Columns
Determines which columns the data dictionary summarizes.
All
Summarizes all columns from the data table, including hidden and excluded columns.
All Shown
Summarizes only the columns that are shown in the Columns Manager, excluding hidden or excluded columns.
Selected
Summarizes only the columns that are selected in the Columns Manager.
Categorical Options
Specifies the options for categorical columns.
Choose Stats
Specifies the summary statistics that are included.
Show Unique Values
Displays the number of unique values that are specified by Max Levels for each column.
Show occurrences per value
Available only when Show Unique Values is selected. Displays the number of occurrences of the unique values for each column.
Max Levels
Specifies how many unique values to display.
Continuous Options
Specifies the options for continuous columns.
Choose Stats
Properties
Specifies the column properties that are included.
Formula
Displays the formula that is used for any formula columns. See “Create Formulas in JMP”.
List Check
Displays the list check used to validate the data in a column.
Value Labels
Displays value labels.
Value Scores
Displays the value-score pairs for the column.
Aliases
Displays any aliases available for column names.
Preview
Displays a preview of the data dictionary that will be created with the selected settings.
