Publication date: 01/13/2026
Compact Character Columns
Character columns in a data table can use significant space in memory and on disk. Compact character columns reduce memory usage by storing each distinct value in a character column only once. Compact character columns can be enabled in preferences or through the Column Info window.
To enable compact character columns
1. Select File > Preferences and click General.
2. Select Open character columns as compact columns.
3. Select New character columns default to compact.
4. Click OK to return to the data table.
Column Types that Benefit the Most
The columns that receive the largest performance benefit from compact character columns have low proportions of distinct values. For example, a column of the names of students where almost every value is unique receives fewer benefits than a column of “yes” and “no” answers to a survey.
File Compression and Compact Character Columns
A table that is saved with file compression can use significantly less space than one that is saved without it. Compact character columns can be used in place of or in conjunction with file compression for a variety of benefits.
Performance
File compression saves disk space, but it comes at the cost of performance. An uncompressed data table loads and saves much faster than when file compression is used.
Because a data table that uses compact character columns are usually much smaller than an identical data table that uses normal character columns, compact character columns give the performance benefits of uncompressed files while saving disk space and memory usage.
Memory Usage
For users whose primary concern is saving memory, using file compression in addition to compact character columns can provide significant benefits.
Compatibility
Compact character columns are not compatible with JMP 17 and earlier.
