Discovering JMP > Visualize Your Data > Compare Multiple Variables
Publication date: 01/13/2026
Use multiple-variable graphs to visualize the relationships and patterns between two or more variables. This section covers the following graphs:
Table 4.1 Multiple-Variable Graphs
Compare Multiple Variables by Using Scatterplots
Compare two continuous variables with scatterplots.
Compare Multiple Variables by Using a Scatterplot Matrix
Compare several pairs of continuous variables with scatterplot matrices.
Compare Multiple Variables by Using Side-by-Side Box Plots
Compare one continuous and one categorical variable with side-by-side box plots.
Compare Multiple Variables by Using a Variability Chart
Compare one continuous Y variable to one or more categorical X variables with variability charts. Variability charts show differences in means and variability across several categorical X variables.
Compare Multiple Variables by Using Graph Builder
Create and change graphs interactively with Graph Builder.
Compare Multiple Variables by Using Overlay Plots
Compare one or more variables on the vertical axis to another variable on the horizontal axis with overlay plots. Overlay plots are especially useful if the X variable is a time variable because you can compare how two or more variables change across time.
Compare Multiple Variables by Using Bubble Plots
Represent up to five variables at once with bubble plots. Bubble plots are specialized scatterplots that use color and bubble sizes for comparison. If one of your variables is a time variable, you can animate the plot to see your other variables change through time.
