Using JMP > Save and Share Your Data > Create Journals > Control the Display of Outline Levels in Journals
Publication date: 01/13/2026
You can instantly control which outline levels are displayed (for example, closing all sublevels below the selected level). Click the red triangle for that level, select OutlineBox, and then select one of the Open or Close options. For more information about the Open and Close options, see “Display Options for JMP Reports”.
Tip: On Windows, show the OutlineBox options by pressing Alt and right-clicking the outline level’s gray disclosure icon.
