Publication date: 01/13/2026
Cox Mixtures
In the Fit Least Squares report, the Cox Mixture option appears only for mixture models. The Standard Least Squares personality of the Fit Model platform fits mixture models using the parameterization suggested in Scheffé (1958). The parameters for this model cannot easily be used to judge the effects of the mixture components. The Cox Mixture model is a reparameterized and constrained version of the Scheffé model. Using its parameter estimates, you can derive factor effects and the response surface shape relative to a reference point in the design space. See Cornell (1990) for a complete discussion.
The Cox Mixture option opens a window that enables you to specify the reference mixture. If you enter components for the reference mixture that do not sum to one, then the components are proportionately scaled so that they do sum to one. The rescaled mixture is shown in the report as the Reference Mixture. The component effects also appear in the report. A Cox component effect is the difference in the predicted response as the factor goes from its minimum to maximum values along the Cox effect direction. For an example, see “Example of Cox Mixtures”.
