Using JMP > Customize Menus and Toolbars
Publication date: 01/13/2026
Personalize JMP
This chapter describes how to customize JMP menus and toolbars to show only the options that you need. For example, you might assign a shortcut key to the Run Script option.
Customizing JMP also lets you set up JMP for groups with special interests. If one group does not design experiments, you could remove DOE from the JMP menu.
Note: When you upgrade to JMP 19 Subscription, changes to preferences are maintained.
Contents
Customize JMP Toolbars and Menus on Windows
Customize Toolbars
Customize the Main Menu Bar
Create Menu Items and Toolbar Buttons
Set User Permissions for Customized Toolbars and Buttons
Rearrange Toolbars
Copy and Paste Menus, Menu Items, Toolbars, and Buttons
Rearrange Custom Menus, Menu Items, and Buttons
Delete Custom Items
Show or Hide Custom Items
Import Customizations
Remove Customizations from JMP
Customize Toolbars on Apple macOS
Customize Menus on Apple macOS
Customize Menus and Toolbars for Add-Ins
