Using JMP > Customize Menus and Toolbars > Customize JMP Toolbars and Menus on Windows > Set User Permissions for Customized Toolbars and Buttons
Publication date: 01/13/2026
Use the JMP Menu Editor to specify which users can see your customized toolbars and buttons. Your changes are saved in a text file with the .jmpcust extension, referred to as a customization set. By default, your customizations are shown to the current user only; other users who log on to the computer and open JMP do not see your personal toolbars and menus.
All customization sets include the built-in JMP buttons and menus. You can also base customization sets on other customization sets. For example, you might create a new customization set that shows the JMP add-in menus and toolbars along with your modifications.
When you modify the Current user customization set, JMP creates a backup file of the set. The file is located in your Windows Users folder within the JMP or JMPPro folder.
C:\Users\<user name>\AppData\Roaming\JMP\JMP\19\
When you modify the All users customization set, JMP creates a backup file of the set. The file is located in the Windows All Users folder within the JMP or JMPPro folder.
C:\Users\All Users\JMP\JMP\19\
The All Users folder does not appear when you try to browse for it, so you must enter the path in the Windows Explorer address field.
Note: To find the customization set files in Windows Explorer, show all hidden files in the Windows Explorer Folder Options. See your operating system documentation for details.
To change the customization set, follow these steps:
1. Select View > Customize > Menus and Toolbars.
The Menu Editor appears.
2. Click Change.
When you try to change the customization set, and changes to the selected set are not saved, you are prompted to save the changes. Click Save Changes.
3. Select the customization set in the Customization Set to Modify area.
By default, changes apply only to the Current user customization set. For a description of the options, see Customization Set Options.
4. (Optional) To change the set on which the selected customization set is based, select the set in the Starting Set area.
This option is not available for the All users customization set. For a description of the options, see Customization Set Options.
5. Click OK.
