Publication date: 01/13/2026
Detection Limits
The table in the Detection Limits section contains a row for each process column that was specified in the Manage Limits launch window. For each column, you can add lower and upper detection limits.
Buttons
There are several buttons at the bottom of the Manage Limits report that provide the following options:
Load from Limits Table
Loads specification limits and metadata from a JMP data table.
Save to Column Properties
Saves the specification limits and metadata as column properties in the associated data table.
Save to Tall Limits Table
Saves the specification limits and metadata to a new data table in tall format.
Save to Wide Limits Table
Saves the specification limits and metadata to a new data table in wide format.
Save to Column Properties in Split Table
(Available only if there is a grouping variable.) Saves the specification limits and metadata as column properties in a new data table split by the grouping variables.
