Publication date: 01/13/2026
Manage Limits
Manage Limits for Many Columns
The Manage Limits platform enables you to quickly add or edit many limits or column property metadata for several columns at once. The limits and metadata are then used in future analyses. You can also specify importance values for each process and indicate whether limits should appear in graphs as reference lines.
The following types of limits and metadata can be specified in Manage Limits:
• Specification limits
• Importance values
• Process Screening metadata, such as centerline, control chart sigma, and measurement sigma
• Measurement Systems Analysis metadata, such as tolerance range, lower tolerance, upper tolerance
• Measurement Systems Analysis metadata specific to Type 1 Gauge analysis, such as reference and resolution
• Detection limits
• Process Capability Distribution
Contents
Example of Manage Limits
Launch the Manage Limits Platform
The Manage Limits Report
Process Capability
Process Screening
MSA
Detection Limits
Buttons
Manage Limits Options
