Publication date: 01/13/2026
Example of Mean Score with Comparison Letters
In the Categorical platform, use the mean score to evaluate a categorical response using a numeric outcome. To control the value assigned to each categorical level, assign Value Scores to the column values. For more information about column properties, see “Set JMP Column Properties” in Using JMP.
1. Select Help > Sample Data Folder and open Consumer Preferences.jmp.
2. In the data table, right-click the Employee Tenure column heading and select Column Properties > Value Scores.
3. Enter 1 for Value and 3 for Score and click Add.
4. Enter 2 for Value and 7.5 for Score and click Add.
5. Enter 3 for Value and 15 for Score and click Add.
6. Enter 4 for Value and 25 for Score and click Add.
7. Click OK.
8. Select Analyze > Consumer Research > Categorical.
9. Select Employee Tenure and click Responses on the Simple tab.
10. Select School Age Children and click X, Grouping Category.
11. Click OK.
12. Click the Categorical red triangle and select Mean Score.
13. Click the Categorical red triangle and select Mean Score Comparisons.
14. Click the gray Mean Score Comparisons disclosure icon.
Figure 3.42 Categorical Report with Mean Score Comparisons
The mean employee tenure for those with school age children is 10.17 and 9.53 for those without school age children. Because the means are not statistically different, the Compare Means column in the crosstab table is empty. If there were a difference, a letter would indicate the difference. The Mean Score Comparisons table provides the group means, their difference, a forest plot, and the p-value for the test of group differences. If you had not used value scores, then the mean for those with school age children would be 2.20 and 2.057 for those without school age children.
Tip: Be aware of how your data are recorded when using the mean score option. If your data are recorded as coded numeric data with value labels, the mean value calculations are based on the numeric data. If the numeric values do not have meaning, use the Value Score column property to assign meaningful values to the response levels.
