Predictive and Specialized Modeling > Explore Outliers > Explore Outliers Platform Options
Publication date: 01/13/2026
The Explorer Outliers red triangle menu contains the following options:
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
