Publication date: 01/13/2026
Explore Outliers
Find Outliers in Univariate and Multivariate Data
The Explore Outliers platform enables you to identify, explore, and manage outliers. Exploring and understanding outliers in your data is an important part of analysis. Outliers in data can be due to mistakes in data collection or reporting, measurement systems failure, the inclusion of error or missing value codes in the data set, or simply an unusual value. The presence of outliers can distort estimates and bias results toward those outliers.
Outliers inflate the sample variance. Sometimes retaining outliers in data is necessary, however, and removing them could underestimate the sample variance and bias the data in the opposite direction.
Whether you remove or retain outliers, it is a good practice to locate them. There are many ways to visually inspect for outliers. For example, box plots, histograms, and scatter plots can easily display these extreme values. See “Visualize Your Data” in Discovering JMP.
Figure 22.1 Multivariate k-Nearest Neighbor Outlier Example
Contents
Overview of Explore Outliers
Quantile Range Outliers
Robust Fit Outliers
Robust PCA Outliers
K Nearest Neighbor Outliers
Example of Explore Outliers
Launch the Explore Outliers Platform
The Explore Outliers Report
Quantile Range Outliers Report
Robust Fit Outliers Report
Robust PCA Outliers Report
K Nearest Neighbors Report
Explore Outliers Platform Options
Additional Example of the Explore Outliers Platform
