Publication date: 01/13/2026
Factor Profiling
In the Fit Least Squares report, the Factor Profiling options in the Response red triangle menu help you explore and visualize your estimated model. You can explore the shape of the response surface, find optimum settings, simulate response data based on your specified noise assumptions, and transform the response if needed.
The Profiler, Contour Profiler, Mixture Profiler, and Surface Profiler are extremely versatile tools whose use extends beyond standard least squares models. For more information about their interpretation and use, see Profilers.
If the response column in your model contains an invertible transformation of one variable, the profilers and Interaction Plots show the response on the untransformed scale.
This section contains information about the output of some of these options.
• Profiler
• Interaction Plots
• Contour Profiler
• Mixture Profiler
• Cube Plots
• Box-Cox Y Transformation
• Surface Profiler
