Publication date: 01/13/2026
Fit Group Options
In the Fit Model launch window, when you specify more than one Y and you select the Fit Separately option for Standard Least Squares, the responses are grouped in a report called Fit Group. The Fit Group red triangle menu includes the following options:
Profiler
Shows or hides a prediction profiler for all responses. You can view the effects of model terms on all responses simultaneously. You can also perform multiple optimizations across the responses. See Profiler.
Contour Profiler
Shows or hides a contour profiler for all responses. You can explore the effects of model terms on all responses simultaneously. See Contour Profiler.
Surface Profiler
Shows or hides separate surface profiler reports for each response. See Surface Profiler.
Mixture Profiler
(Available only if there are mixture factors.) Shows or hides a mixture profiler that shows the contours of the response on a ternary plot. See Mixture Profiler and “Mixture Profiler” in Profilers.
Arrange in Rows
Rearranges the reports for the platform analyses in a specified number of rows. This can be used to arrange reports so that more reports fit in a window or on the page of output.
Order by Goodness of Fit
Sorts the reports by significance of fit (R-square). This option is available only for platforms that surface the R-square to the platform level. For example, if you generate hundreds of Oneway analyses from one launch window, they appear in a FitGroup and you can sort them so that the strongest relationships appear first.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
