Publication date: 01/13/2026
Graph Zones
The main element in the Graph Builder window is the graph area. The graph area contains zones, and you drag and drop variables from the Variables box into the zones.
Tip: If you drop variables into the center of the graph, JMP guesses the drop zone to put them into, based on whether the variables are continuous, ordinal, or nominal.
There are two types of zones into which you can drag variables:
• Data zones include X, Y, Map Shape, Freq, Color, Size, and Interval. The X, Y, and Map Shape zones are positional and influence the types of graph elements that are available. The Freq, Color, Size, and Interval zones modify certain graph elements.
• Grouping zones partition the data into subsets that repeat the graph for each possible subset. Grouping zones include Group X, Group Y, Wrap, Overlay, and Page.
The following zones are available in Graph Builder:
Table 3.5 Graph Builder Zones
Zone
Description
X and Y
Constructs plots that are based on the values, levels, or categories of the variables that you drop into these zones. Use the X zone for a horizontal layout and the Y zone for a vertical layout.
Group X and Group Y
Stratifies your data by the levels of the nominal or ordinal variable and constructs a plot for each level. Group X produces a horizontal display, and Group Y produces a vertical display.
The variable type that you put in Group X or Y also determines aspects of the display:
• Adding a continuous variable creates nonoverlapping interval subgroups and plots for the values in each interval.
• Adding a categorical variable creates plots for each level of the categorical variable.
You can add multiple variables to Group X or Group Y:
• To add a variable above a variable in one of the Group zones, drag it to the left of that variable in the Group X zone or above that variable in the Group Y zone.
• To add a variable below a variable in one of the zones, drag it to the right of that variable in the Group X zone or below that variable in the Group Y zone.
To stratify by the levels of two variables, drag a variable into both Group X and Group Y. To change the number of levels that appear, right-click in the axis border and select Levels in View. For a description of all options, see Options for Axes, Axes Variable Labels, or Graph Titles.
Map Shape
Adds a map. Your variable must contain geographic place names, such as countries, regions, states, or provinces, or you must provide information in a custom shape file. Note the following tips:
• If you drag and drop columns that are labeled Latitude and Longitude, JMP automatically assigns them to the Y and X roles (respectively).
• When you drop a variable into the Map Shape zone, the X and Y zones disappear.
• The Map Shape element can be used with the Points element to place points within the shape.
For more information about creating map shapes, see Red Triangle Option for Formula and “Add a Map to Graph Builder”.
Wrap
Creates rows of plots for the levels of a categorical variable or for the interval subgroups of a continuous variable. Use Wrap when your stratifying variable has many levels. To change the number of levels that appear, right-click in the axis border and select Levels in View. For a description of all options, see Grouping Zones Options.
Note: After a variable is placed here, no variable can be placed in Group X.
Overlay
Subgroups and colors the plot elements according to the levels of the Overlay variable.
• Adding a nominal or ordinal variable stratifies and colors the plot elements by the levels of the variable.
• Adding a continuous variable creates interval subgroups. The plot elements are stratified and colored according to the subgroups.
A legend appears to the right of the plot. Right-click on legend items for customization options.
Color
Adds color to points, map shapes, and other objects.
• Adding a nominal or ordinal variable colors the plot elements by the variable’s levels.
• Adding a continuous variable colors the plot elements according to an intensity scale.
A legend appears to the right of the plot. Right-click in the legend to change colors or to customize the intensity scale.
Tips:
• After you add a variable in the Color zone, you can show or hide color by using the Variables option in the element properties panel.
• You can assign up to 10 variables to the Color zone.
Size
Sizes graph elements by a summarizing statistic or other size variable.
Tip: You can assign up to 10 variables to the Size zone.
Interval
Add interval variables to draw custom error bars.
• A single interval variable is treated as a delta to compute upper and lower ends of the interval.
• Two interval variables are treated as lower and upper values for the interval.
Tip: You can assign up to 10 variables to the Interval zone. However, because each element uses only one or two, if you assign more than two variables, you must use the Variables option to specify which variables to use.
Freq
Add a frequency or weight variable. When all values are integer values, the Freq variable is treated as a frequency. Otherwise, it is treated as a weight. A footer note indicates how the variable is treated. The Freq variable affects summary statistics.
Page
Drop a By group variable to the Page zone to show each level of the group on a separate graph. By default, the Page zone is limited to 200 pages. The first 200 categories are displayed. Adjust this limit in the Graph Builder preferences. See “Preferences by JMP Platform” in Using JMP.
Tips:
• After you click Page, you can select Link Page Axes in the red triangle. Use this option to link or unlink graph axis scales across levels of the By group variable in the Page zone.
• To copy individual graphs by using the selection tool, first save the Graph Builder output to a journal (Edit > Journal).
For more information about the legend, see Legend Options in Graph Builder.
Note: When you use categorical values in zones that are associated with summarization roles like Y and Color, summary statistics are calculated based on numerical values that are assigned to the variable levels (integer values that range from 0 to the number of levels minus one). The final result is then mapped back as a level to a corresponding categorical value or value range. This approach allows the use of ordinal variables in summarization, but might not lead to clear results for nominal variables.
