Publication date: 01/13/2026
Import Settings
Use the Settings window in Multiple File Import for options for importing CSV, XML, JSON, PDF, and Excel files.
CSV Settings
Headers and Data Lines
Make Numeric Columns from Numeric Data
Specifies whether to import numeric data into numeric columns or character columns. This option is selected by default.
Has Headers
Specifies if the CSV file has headers. This option is selected by default.
First Header Line
Specifies the first header line of the CSV file. This option is set to 1 by default.
Number of Header Lines
Specifies the number of header lines. Multiple header lines are collapsed into one line with fields separated by an underscore. This option is set to 1 by default.
First Data Line
Specifies the first data line of the CSV file. This option is set to 2 by default.
Unusual Files
Quote
Specifies the character that is used in the file as a quotation mark if the character is not a double quotation mark (“).
Escape
Specifies the character that is used in the file as an escape delimiter for special characters, such as a backslash (/). CSV files typically do not use escape delimiters.
End of Field
Most CSV files use commas as the marker for the end of a field. Others use characters, such as tabs or spaces. Select any combination of the options in the End of Field box that best match the field delimiters of the files that you are importing.
End of Line
Most CSV files use line breaks to mark the end of a row. However, some files might use the carriage return <CR> character, the linefeed <LR> character, or a semicolon to indicate the end of a row. Select any combination of the options in the End of Line box to account for the characters that your files use to mark the end of the line.
XML, JSON, and PDF Settings
Guess values from file
MFI supports several options for guessing data table values from XML, JSON, and PDF files.
Tall guess
Selects the element that makes as many rows as possible.
Wide guess
Selects the element that makes as many columns as possible.
Huge guess
Selects as many elements to make rows as it needs to get all of the data into the table. This guess is selected by default.
Caution: Tables created using Huge guess can be very large.
Pandas guess
The most accurate method for creating a data table from JSON files that are in a Pandas format.
Script
Creates the data table with a user-provided JSL script.
Excel Settings
Create column with worksheet name
Creates a column with the worksheet name for each row of data that is imported from a workbook. This option is useful when importing files with multiple worksheets per workbook. This option is deselected by default.
Auto detect during import
Automatically detects Excel worksheet parameters such as headers, row and column suppression, and cell colors during import. This option is selected by default.
Worksheet name filter
Specifies the name of the worksheets to import. Worksheet names that do not match the filter are ignored. This field is empty by default.
Headers and Data
Has Headers
Specifies whether the file contains column headers. Deselect if the file does not contain column names.
Replicate headers in spanned rows
If there are multiple header rows and a cell spans those rows but does not span any cells horizontally, the value in the start of the merged area are repeated when creating the column header. This option is deselected by default. The option is not available if Number of rows with column headers is less than two.
Treat multiple column header lines as hierarchies
Reorganizes information from spanned cells in the headers and places that data into the rows of the generated table.
Column headers start on row
Specifies the row where column headers begin. This field is 1 by default.
Specifies the number of rows with column headers. JMP collapses multiple headers into one, and the fields are separated by an underscore.
Data starts on row
Specifies the first row that contains data. This field is set to 2 by default.
Data starts on column
Specifies the first column that contains data. This field is set to 1 by default.
Data ends with row
Specifies the last row that contains data.
Data ends with column
Specifies the last column that contains data.
Column Name Separator String
Specifies the string to be used as a separator when concatenating multiple cells into column header names.
Options
Suppress hidden rows
Removes hidden rows in the imported files from the created data table.
Suppress hidden columns
Removes hidden columns in the imported files from the created data table.
Suppress empty columns
Removes empty columns in the imported files from the created data table.
Replicate data in spanned rows
If a cell spans multiple rows but does not span any cells horizontally, the value in the start of the merged area are repeated. This option is selected by default.
Multiple series stack
Stacks multiple column header lines into a hierarchy. This option is deselected by default. The option is not available if Treat multiple column header lines as hierarchies is deselected.
Import cell colors
Specifies whether to import the cell colors that are used in the original file. This option is deselected by default.
Limit column type detection
Specifies whether to check every cell of the imported data to determine the column types to assign. This option is deselected by default.
