Fitting Linear Models > Multivariate Response Models > Multivariate Tests in Multivariate Response Models
Publication date: 01/13/2026
In the Manova Fit report, the M Matrix report gives the response design that you specified. The M-transformed Parameter Estimates report gives the original parameter estimates matrix multiplied by the transpose of the M matrix.
Note: Initially in this chapter, the matrix names E and H refer to the error and hypothesis cross products. After specification of a response design, E and H refer to those matrices transformed by the response design, which are actually M´EM and M´HM.
This section contains information about the following topics:
• The Extended Multivariate Report
• Comparison of Multivariate Tests
• Univariate Tests and the Test for Sphericity
