Publication date: 01/13/2026
Profiler Features in JMP
There are several profilers in JMP and each have a different set of features. The profilers are accessible from most fitting platforms and the main menu under Graph. When you launch a profiler from the Graph menu, you must specify formula columns.
Table 2.1 Profiler Features Summary
Description
Features
Prediction Profiler
Shows vertical slices across each factor, holding other factors at current values
Desirability, Optimization, Simulator, Propagation of Error
Contour Profiler
Horizontal slices show contour lines for two factors at a time
Simulator
Surface Profiler
Three-dimensional plots of responses for two factors at a time, or a contour surface plot for three factors at a time
Surface Visualization
Mixture Profiler
A contour profiler for mixture factors
Ternary Plot and Contours
Custom Profiler
A non-graphical profiler and numerical optimizer
General Optimization, Simulator
Excel Profiler
Visualize models (or formulas) stored in Excel worksheets.
Profile using Excel Models
Profiler availability is shown in Table 2.2. The Custom Profiler is available only through the Graph menu. (Model Comparison does have Custom Profiler available.)
Table 2.2 Where to Find JMP Profilers
Location
Profiler
Contour Profiler
Surface Profiler
Mixture Profiler
Graph Menu (as a Platform)
Yes
Yes
Yes
Yes
Fit Model: Least Squares
Yes
Yes
Yes
Yes
Fit Model: Generalized Regression
Yes
Fit Model: Mixed Model
Yes
Yes
Yes
Yes
Fit Model: Logistic
Yes
Fit Model: Loglinear Variance
Yes
Yes
Yes
Fit Model: Generalized Linear Model
Yes
Yes
Yes
Fit Model: Partial Least Squares
Yes
Neural
Yes
Yes
Yes
Partition
Yes
Bootstrap Forest
Yes
Boosted Tree
Yes
Support Vector Machines
Yes
Yes
Yes
Model Screening
Yes
Model Comparison
Yes
Yes
Yes
Yes
Nonlinear: Factors and Response
Yes
Yes
Yes
Nonlinear: Parameters and SSE
Yes
Yes
Yes
Nonlinear: Fit Curve
Yes
Functional Data Explorer
Yes
Gaussian Process
Yes
Yes
Yes
Discriminant
Yes
Yes
Structural Equation Models
Yes
Life Distribution
Yes
Fit Life by X
Yes
Yes
Recurrence Analysis
Yes
Choice
Yes
Custom Design Prediction Variance
Yes
Yes
