Publication date: 01/13/2026
Reference Namespaces and Scopes
There are a number of factors in resolving a named variable reference in a JSL script. Table 8.6 describes the named variable references that are resolved for specific situations.
Notes:
• In JMP 9 and later, a, :a, and ::a have the same meaning with the Names Default To Here mode turned off.
• If the current point of execution is in a user-defined function, or a Local or Parameter JSL function body, then the Local namespace is used for creation when Default Local is specified. However, the reference rule is unchanged.
Table 8.6 Namespace References
Form
Reference Type
Reference Rule
Creation Rule
a
Unqualified
If the Names Default To Here mode is on, JMP looks for the variable in these locations:
• Local namespace
• Here namespace
• Current data table
If the Names Default To Here mode is off, JMP looks for the variable in these locations:
• Local namespace
• Here namespace
• Global namespace
• If the Names Default To Here mode is on, then JMP creates the variable in the Local namespace or in the Here namespace.
• If the Names Default To Here mode is off, then JMP creates the variable in the Local namespace or in the Global namespace.
:a
Current data table
JMP looks for the variable in the current data table.
(Not applicable)
::a
Global:a
Global
JMP looks for the variable in the Global namespace.
JMP creates the variable in the Global namespace.
ns:a
dt:a
Here:a
"name":a
expr:a
Qualified
JMP looks for the variable in the specified namespace. If the variable is not found, an error results.
JMP creates the variable in the specified namespace. Any previous values are replaced.
ns["a"]
ns[expr]
Subscript
Platform:a
Qualified
JMP looks for the variable in the encapsulating platform.
JMP creates the variable in the encapsulating platform.
Local:a
Qualified
JMP looks for the variable within any nested local function, up to and including a function call boundary. See Example of Local:a.
JMP creates the variable in the innermost nested local function or function call boundary.
Window:a
Qualified
JMP looks for the variable in the encapsulating New Window window namespace.
JMP creates the variable in the encapsulating New Window window namespace.
Box:a
Qualified
JMP looks for the variable in the encapsulating Context Box namespace contained in a New Window window.
JMP creates the variable in the encapsulating Context Box namespace contained in a New Window window.
Example of Local:a
Sample Script
Log Output
Delete Symbols();
Local( {d1l1 = 12},
local:f1f1 = Function( {fa1, fa2},
{fl1 = 99},
local:fa12 = fa1 + fa2;
Local( {d2l1 = 56},
local:l2l2 = 78;
Show( fa12 );
Show( fl1 );
Try( Show( d1l1 ), Write( "\!n\!n***Error=" || Char( exception_msg ) || "\!n" ) );
Show Symbols();
local:fa12;
f1f1( 2, 3 );
fa12 = 5;
fl1 = 99;
dil1 = 12;
// Local
d2l1 = 56;
l2l2 = 78;
// 2 Local
// Local
fa1 = 2;
fa12 = 5;
fa2 = 3;
fl1 = 99;
// 4 Local
// Local
d1l1 = 12;
// 1 Local
5
