Publication date: 01/13/2026
Save Columns
In the Fit Least Squares report, the Save Columns options in the Response red triangle menu add one or more new columns to the current data table. Additional Save Columns options appear when the fitting method is REML. These are detailed in REML Save Columns Options.
• When formulas are created, they are entered as Formula column properties.
• For many of the new columns, a Notes column property is added describing the column and indicating that Fit Least Squares created it.
• For the Predicted Formula and Predicted Values options, a Predicting column property is added. This property is used internally by JMP in conducting model comparisons (Analyze > Predictive Modeling > Model Comparison). When you fit many models, it is also useful to you because it documents the origin of the column.
This section contains information about the output of some of these options.
• Prediction Formula
