Using JMP > Save and Share Your Data > Save Data Tables > Save Data Tables to a SQLite Database File
Publication date: 01/13/2026
When saving to a SQLite database file, each JMP table is saved as one SQLite database file. To save data tables to a SQLite database file, follow these steps:
Windows
1. With the specific data table open in JMP, select File > Save As.
2. Select SQLite Database File from the Save as type list.
3. Enter the file name.
4. Select the location for the file.
5. Click Save.
Apple macOS
1. Select File > Export.
2. Select SQLite Database File and click Next.
3. (Optional) Rename the file.
4. Click Export.
