Publication date: 01/13/2026
Save Data Tables
Select File > Export or File > Save As to save a data table in another format such as a Microsoft Excel or CSV file.
Note: To save a data table as a journal, select Edit > Journal and then File > Save As.
JMP saves data tables in the formats that are listed in Table 11.1.
Table 11.1 Supported File Types for Saving Data Tables
File Types
OS Availability
JMP data table (.jmp)
All
Excel workbook (.xls, .xlsx)
All
Text export file (.txt)
All
Comma-separated value file (.csv)
Windows
Tab-delimited file (.tsv)
Windows
SAS data set (.sas7bdat)
All
SAS data set with extended attributes (.sas7bxat)
Note: JMP can save column properties and table properties as extended attributes in a SAS 9.4 .sas7bxat file. Select File > Export, select the SAS file type, and then select the check box for saving extended attributes. JMP names the file with the .sas7bxat extension. The Third Party Data preferences also include this option, which is turned off by default.
Windows
SAS transport file (.xpt,.stx)
All
JSON data file (.json)
All
SQLite database file (.sqlite, .db, .sqlite3, .db3)
All
You can also save files for types that have a corresponding Open Database Connectivity (ODBC) driver. See Save Data Tables to a Database.
Notes:
• The maximum length of the data table’s name depends on your computer’s operating system. See your operating system’s documentation for details.
• JMP tries to save any modified files when a crash is detected.
