Essential Graphing > Parallel Plots > The Parallel Plot
Publication date: 01/13/2026
The Parallel Plot
A parallel plot is one of the few types of coordinate plots that show any number of variables in one plot. However, the relationships between variables might be evident in the following circumstances only:
• When the variables are side by side
• If you assign a color to a level of a variable to track groups
• If you select lines to track groups
Note: To produce the plot that is shown in Figure 7.5, follow the instructions in Example of a Parallel Plot.
Figure 7.5 The Parallel Plot Report
Tip: You can add reference lines for specification limits. For information, see “Spec Limits” in Using JMP.
